Skumt problem med värmenyp (nya bilder på kolv!)
Robbbb
10 mar 2006
356
övik
Nä jag vet inte, minns bara att på min gamla polaris så såg den ut sådär när oljebehållaren hade sprungit läck.
2stroke
31 dec 1999
4.445
www.lynxtalk.se
Piston Wash !
Piston Wash – How Much ?
2-stroke engine tuners know that observing the amount of piston wash on the piston dome is a very accurate indicator as to the best fuel-air mixture for maximum power production in competitive situations. These small “clean areas” on top of the pistons, located where the fuel enters the combustion chamber at the transfer ports, are indicative of the amount of excess fuel entering the engine.
The smaller the “wash”, the leaner the fuel-air mixture.
How much is the perfect piston wash ?
You should keep two important items in mind when looking at the wash on top of the pistons....
1. * Engines with flat top pistons can run less wash and not lose performance or detonate.
2. * The domed pistons need to run more wash than a flat top piston in order for the engine to run at peak performance.
* Flat top piston wash, at peak performance, will be the size of the nail on your little finger.
You can get slightly smaller than this, but then the performance will begin to go down hill and the detonation point gets closer.
* Domed style pistons need to have a wash the size of the nail on your thumb or slightly less.
Remember, the amount of piston wash explained above is based on regular octane fuel.
Running race fuel, if you have the compression to burn it, will allow the size of the wash to become less through jetting and not lose as much HP.
If you are into getting the most out of your engines,
use this rule of thumb to keep enough fuel thrown at it and avoid the burndowns.
Lone
Gällivare, Sverige
Vatten på stiftet och vatten i cylindern, var kommer det ifrån?
Du kör väl inte med filter på gasarna? Orginalluftburken fungerar i 99 fall av 100 bättre.
Max_K
15 sept 2007
2.534
Koskullskulle
Jag kör med originalluftburk! Packningarna runt tändstifthålet var dåliga, och det har läkt ut avggaser i glykolen, så den var grå. Men det konstiga var att det inte har försvunnit nått vatten alls :confused:
Pyrro
12 sept 2005
2.807
Varför lita blint på vattennivån?
Det är väll bara byta alla packningar kolvar osv.
Upp med lädret bara.
Robbbb
10 mar 2006
356
övik
Du får byta packningarna, sen får du ta och gå igenom förgasare så att inget inte stämmer, kanske bestycka upp lågfarten lite, iaf tills kolvarna är riktigt inkörda..
Max_K
15 sept 2007
2.534
Koskullskulle
Yes, har kollat igenom förgasarna, lufskruvarna var utskruvade 3varv. Är det bra?
Får kolla mer imorn, nu knäcker jag några bärs :beer:
Robbbb
10 mar 2006
356
övik
Bränsleskruvar är de:), 1.5 varv tror jag de är original. Tyck du ska göra den original i bestyckningen igen.
Max_K
15 sept 2007
2.534
Koskullskulle
Ska det bara vara 1.5varv? Det enda som verkar vara bytt är lågfarten till 15 istället för 17.5. Och den dricker ungefär dubbelt så lite nu.
Max_K
15 sept 2007
2.534
Koskullskulle
Har jag nicasil i mina cylindrar? Har inte fått kläm om det var nicasil på 500an. Om det skulle vara det, så kan man hona med sten nr500 om jag kom ihåg rätt?
Nestander
17 jan 2007
1.364
Jag kör på 480 MJ, 15 PJ och bränsleskruven 1,5 varv ut. Funkar mycke bra för mig iaf, 470 var i hållet på snålt, vill vara safe.
Nestander
17 jan 2007
1.364
Testa att kolla med en magnet i cylindern om den är magnetisk, icke magnetisk = nicasil.
Att horna en nicasil cylinder går bara fint tror jag, är dock inte 100.
DennisA
14 sept 2007
318
Sweden
öppna upp och kolla det lilla plast drevet i oljepumpen, brorsans kolvar såg lika dana ut och då va drevet av
Robbbb
10 mar 2006
356
övik
Nu äre ju dock bara en kolv. Snurrar inte de drevet så snurrar inte vattenpumpen heller.
Max_K
15 sept 2007
2.534
Koskullskulle
Precis. Men ska kolla oljepumpsaxeln också, så att den snurrar när motorn går runt. För det gjorde vattenpumpen iallafall
