The ETEC is a very hard sled to modify.. WHY? Because the computer module is monitoring MANY parameters!! One such parameter is crank acceleration.. Hmmm.. This is a biggy.. it actually measures how fast the crank is accelerated from X RPM to Y RPM... AND IF this acceleration is out of spec for the engine.. Guess what??? it adjusts to bring it in spec.. So, if you add some power, this will accelerate the the crank faster.. So, now the computer will "DE-TUNE" the engine to bring this "too fast" acceleration back in line with stock. and this is just ONE area they are monitoring....
So, what does all this mean??? it means that ANY HP you give to the ETEC, it will do its best to REMOVE and return the engine to stock operating power output.. It really is that simple!!!.. So, all this talk of big bores and heads, and such, will not be continuous.. meaning..SHORT LIVED..
BRP has STRICT orders with Evinrude to NOT allow ANY ECM altering.. So, there is NOBODY (unless BRP authorizes it for their OWN company R&D) that can get into this box and alter ANY parameters!
The Bottom Line is this: With the ETEC, Stock or very close to stock power is what you get and what you will always get unless you add another controller.
So, people, please be careful when you hear of some super "Power Enhancer" for the ETEC.. It may do some enhancing, but the ECM will return all "enhancing" back to stock levels in short time.
