Eftersom ingen på forumet verkar vetta detta så postar jag svaret som jag fick på ett annat forum så sprider vi kunskaperna ang. detta ämne. Plus att ni slipper lägga ut 7-800 kr per dämpare för att få dem renoverade.
______________________
KYB Shock Rebuilding Specs
Please take into consideration a qualified shock service shop. Do not attempt to do this on your own. This information is for reference only.
Sleds Ski Shocks Center Rear Shock Rear Shock
Piston Depth Pressure Piston Depth Pressure Piston Depth Pressure
XTC/SX-R/Viper 161 mm 142 psi 120 mm 284 psi 186 mm 284 psi
SX/SRX 129 mm 142 psi 115 mm 284 psi 158 mm 284 psi
RX1/Warrior 184 mm 171 psi 139 mm 284 psi N/A N/A
Expert X N/A N/A N/A N/A 141 mm 300 psi
Note: Piston Depth is from the edge of the cylinder to the edge of the piston. Not the inner (deeper) part of the piston.
N/A = Non Rebuildable or Not available Info
/Grisen
