Jag saxar direkt från holtzman´s hemsida.
Antar att de flesta på den här sidan vet vad detta är för något.
ATACC
(Automatic Temperature and Altitude Carburetor Compensator)
This compensator will automatically keep your carbs tuned through all temperatures and a typical elevation change of up to 8000 feet (2400 meters) (see instructions for other limitations). The standard compensator is set initially for operation with -20F (-29C) carb jetting for use with snowmobiles, but can be set to use with any jetting temperature. It is also easily set for any operating base (minimum) altitude. This compensator is recommended for the mountain rider who wants to play, not jet. The standard ATACC will work on almost any snowmobile except 4-strokes with CV type carbs and it is not recommended for 2001-2002 Ski-Doo's with TM flatslides. We offer a model-specfic kit for Polaris snowmobiles with air box vented TM flatslide racked carbs, but all the ATACC units themselves are the same and therefore a standard snowmobile ATACC can still be used on Polaris.
Pris: 1200kr
ATACC
Pris: 1200kr
58,3 KB Visningar: 39
