Arctic Cat 2015
henrico
Norrland
Dom zoomade in den dekalen i boggien så man trodde nästan det var nåt nytt tjafs ala t-motion eller nåt...
antonbc
17 sept 2012
924
67
folk hajpar ju upp modellerna varje år, är ju sån sjuk hets när det gäller snöskotrar. om man frågar mig :)
egodeus
8 jan 2010
682
Here's the highlights from Arctic Cat for 2015:
  • The big news for Arctic Cat for 2015, for the mountain crowd at least, is the addition of two new 2-stroke models and one new 4-stroke model.
  • The 2015 M6000 153 and M6000 Sno Pro 153 feature Cat's new 6000-Series C-TEC2 engine. This twin-cylinder engine with dual-stage injection features batteryless EFI, electic oil pump, APV electronic power valves, exhaust pipe temperature system (EPTS), knock sensor and engine-reverse technology. The lightweight 599cc engine meets Tier III EPA emissions regulations.
  • The 2015 M7000 Sno Pro 153 features the proven Yamaha 4-stroke triple-cylinder 1049-cc engine. It's a quick-revving EFI with an engine management system that eliminates engine braking.
  • The popular M8000 Sno Pro (the Rob & Dave Special...) returns with several key improvements and upgrades for 2015.
  • Three Special Edition graphics packages are available for 2015: M8000 David McClure Special Edition; M8000 Rob Kincaid Special Edition; ZR 6000 Tucker Hibbert Special Edition.
  • Spring Order incentives: get 6.9% financing for 60 months plus 3-year warranty plus free Cat's Pride membership plus up to $300 Cat Cash plus Limited Edition Leather Jacket. Spring order deadline is April 30, 2014.
2015 M Series updates and improvements:
  • All M models get front-mounted wheel kit on the rear suspension rails that prevent the rail tip from stabbing the track window.
  • All M models get new magnesium idler wheel blocks with 6mm fasteners on rear suspension for reduced weight.
  • All M models get new larger-diameter driven shaft with snap-ring bearing mount instead of taper-lock bearing for improved durability and serviceability.
  • All M models with Fox Float 3 shocks get new bleed shim valving for improved comfort and control in bumps. The air fill port has been moved to the side to make it easier to attach the Float pump for easier calibration.
  • All M Sno Pro models fet added rail braces in the rear suspension for increased durability.
  • M7000 model gets new rear suspension rail profile with longer fron arm shock for improved weight balance.
  • M8000 and M9000 Series Sno Pro and LTD models get new front ProClimb bumper.
k-len
12 jul 2005
8.891
mellansel
www.skoterlon.nu
JÄVLIGT tråkigt att se inte släpper ctec800.
"several more years with the Suzuki Engine"
Som tur var så ska Suzuki inte utveckla fler motorer, så när de andra tillverkar kommer ikapp motormässigt
Så lär det komma en väldigt beprövad C-tec.
Kul att panteran är "tillbaka". Och med 56 liters tank. Så ska alla touringar ha det.
Små uppdateringar på f/Xf/m. Inget att dregla över. Ska vara de extra hjulen längst fram i boggien jag skulle vilja ha.
Och att de numera kallar fatcaten för lynx förklarar en hel del... ;)
Macke78
8 mar 2011
1.554
14
En liten nyhet är väl 40" framvagn på Xf hc, vilket den iof borde haft sen 2012. Nä tunt med nyheter, blir att åka vidare på min gamla 12 som redan har "extra allt".
m0ngoloid
13 aug 2010
5.346
Norsjö
Vart riktigt besviken när inte nya motorn kom..
Och hur fan tänkte dom när dom bestämde färg kombon? Nä får köra med min nått år till då
forre
9 okt 2004
1.231
Vad var det här snacket tidigare om att man skulle lämna samarbetet med Suzuki? Samt att Yamaha skulle leverera 4T och även tillverka egna motorer. Det har uppenbarligen inte gått enligt plan.
Det är ju samma lineup som 2014 förutom små förändringar. Skulle tro att killarna och tjejerna i Thiev river falls får producera många Yamaha iår
k-len
12 jul 2005
8.891
mellansel
www.skoterlon.nu
Ja detta vart som det blev....
Färgsättningarna var förjävliga. Spec spring order tigern (kinclair?)
Men som jag förutspådde så är suza motorn kvar. Finns ingen mening att byta ut något som ändå är marknadsledande.
Kul att hcren får 40" iaf. Blir en sån 2016 om det blir bättre uppdates då.
antonbc
17 sept 2012
924
67
ser ju hellre dom släpper en väl fungerande ctec800 2016 istället för att tvinga ut den på marknaden innan dom är helt nöjda med den. Suzuki 800an är väl inte direkt en dålig motor?? återigen, hetsen i snöskoterbranchen. sen klagar folk på att skotrarna har massa barnsjukdomar, konstigt då...
