Jag har hämtat checklistorna från manualen (Lynx Boondocker DS 2017) för försäsong och före åka.
På Engelska.
Jag hoppas att detta hjälper andra också!
Before Starting the Engine
Post-Operation Care
Shut off the engine. Install rear of vehicle on a wide-base snowmobile mechanical stand.
Remove snow and ice from rear suspension, track, front suspension, steering mechanism and skis.
Always cover your snowmobile when leaving it outside overnight or during extended periods of inactivity. This will protect it from frost and snow as well as help retain its appearance.
En andra är här: https://www.hardcoresledder.com/threads/pre-season-checklist.440578/#post-4885550
På Engelska.
PRE RIDE CHECKLIST | |
ITEM | OPERATION |
BODY INCLUDING SEAT, FOOTRESTS, LIGHTS, AIR FILTER, CONTROLS AND INSTRUMENTS | Check condition and remove snow or ice. |
SKIS AND STEERING ACTION | Check for free movement and proper operation. |
FUEL AND INJECTION OIL (IF APPLICABLE) | Check for proper level and no leaks. |
COOLANT | Check for proper level and no leaks. |
BRAKE FLUID | Check for proper level and no leaks. |
STORAGE COMPARTMENT | Check for proper latching and no heavy or breakable objects. |
TRACK | Check condition and remove snow or ice. |
THROTTLE LEVER | Check for proper operation. |
BRAKE LEVER | Check for proper operation. |
PARKING BRAKE, BRAKE | Check for proper operation. |
EMERGENCY ENGINE STOP SWITCH AND ENGINE CUT-OFF SWITCH (TETHER CORD CAP) | Check for proper action. Tether cord must be attached to operator clothing eyelet. |
LIGHTS | Check for proper operation. |
SKI RUNNERS | Check for proper operation. |
SLIDER SHOES | Check for proper operation. |
DRIVE BELT | Check for cracks, fraying or abnormal wear. |
- Remove snow and ice from body including lights, seat, footrests, controls and instruments.
- Verify that air filter is free of snow.
- Verify that skis and steering operate freely. Check corresponding action of skis versus handlebar.
- Check fuel and injection oil (if applicable) for levels and leaks. Replenish if necessary and in case of any leaks; you should seek service from an authorized Lynx dealer, repair shop, or person of your own choosing for maintenance, repair, or replacement.
- All storage compartments must be properly latched and they must not contain any heavy or breakable objects. Hood and side panels must be also properly latched.
- Activate the throttle control lever several times to check that it operates easily and smoothly. It must return to idle position when released.
- Activate the brake lever and make sure the brake fully applies before the brake control lever touches the handlebar grip. It must fully return when released.
- Apply parking brake and check if it operates properly. Leave parking brake applied.
- Check headlights high beam and low beam, taillight, stop light and pilot lamps operation.
- Check the engine cut-off switch (by pulling tether cord cap) and emergency engine stop switch operation.
- Release parking brake.
Post-Operation Care
STORAGE | |
VEHICLE | Clean the vehicle |
ENGINE | E-TEC models: Lubricate engine. |
Block muffler with rags | |
Protect fuel system by adding fuel stabilizer to fuel following the product manufacturer recommendations. Run the engine after adding the product to the fuel | |
DRIVE SYSTEM AND BRAKE | Lubricate brake lever pivot |
Lift rear of vehicle until track is clear of the ground. Do not release track | |
SUSPENSION | Tension Inspect and lubricate rear suspension |
Lubricate front and rear suspension | |
ELECTRICAL SYSTEM | Charge battery monthly to keep it fully charge during storage |
PRE SEASON PREP (2-Stroke) | |
ENGINE | Inspect engine rubber mounts |
Check exhaust system condition and check for leaks | |
Tighten exhaust manifold screws or nuts to specified torque | |
Inspect cooling system cap, hoses and clamps and check for leaks | |
Check coolant density | |
Inspect crankshaft PTO seal | |
FUEL SYSTEM | Inspect fuel lines and connections |
Inspect throttle cable | |
DRIVE SYSTEM AND BRAKE | Inspect drive belt (adjust at every drive belt replacement) |
Clean and visually inspect drive pulley | |
Clean and inspect driven pulley | |
Inspect, adjust and align track | |
Adjust drive chain (Not for models equipped with gearbox) | |
Change chaincase / gearbox oil | |
Check brake fluid level | |
Inspect brake hose, pads and disk | |
STEERING SYSTEM | Inspect steering mechanism |
Inspect skis and runners | |
SUSPENSION | Inspect front suspension |
Inspect rear suspension (including stopper straps and slider shoes) | |
ELECTRICAL SYSTEM | Inspect spark plugs (All except E-TEC) |
Charge battery (if so equipped) | |
Adjust headlight beam aiming |
