Stoppskruv i vikten
With the cam arm pin properly positioned, apply green Loctite #620 to the set screw holes in the
cam arm, install the new set screws (pre-coated with Loctite), and tighten to 19 in.-lb. (2,1Nm)
Skruven som viten sitter på
Secure the cam arm pins with new lock nuts and tighten to 11 ft-lb. (15Nm)
Yttre kåpan
Place the spring and cover into position making sure the timing mark on the cover is properly aligned; then compress the spring and install the machine screws coated with blue Loctite #243 and
lock washers. In a crisscross pattern, tighten evenly to 120 in.-lb. (13.55Nm)
Bulten i veven
Place the drive clutch into position on the crankshaft and secure with the appropriate cap screw
and lock washer. Tighten to 55 ft-lb. (75Nm)
Du kan översätta siffrorna igen för att kolla att ja gjort rätt.
Finns en tråd här som länkar till en ftp med servicemanualer.
