Arctic Cat 650H1 generatorproblem?
Fix
13 nov 2009
den vill inte ladda batteriet på atv.n..... hur många volt bör det vara fram till laddningrelä/boxen (sitter i bak på maskinen) från generatorns 3 gula trådar(gul,gulorange,gulröd):hello:, ut från boxen borde det vara ca 13V ???
thullen
Leksand
thullen.se
Sv: Arctic Cat 650H1 generatorproblem?
Nedanstående gäller i alla fall årsmodell 2006
Magneto Coils (400/500/650 H1) VOLTAGE (Stator Coil - Regulated Output)
1. Set the meter selector to the DC Voltage position.
2. Connect the red tester lead to the positive battery post; then connect the black tester lead to the negative battery post.
3. With the engine running at a constant 5000 RPM (with the headlights on), the meter must show 14-15.5 DC volts.
Do not run the engine at high RPM for more than 10seconds
NOTE: If voltage is lower than specified, test stator coil - no load.
VOLTAGE
(Stator Coil - No Load)
The connector is the black and white one on the right side of the engine just above the brake cable adjuster.
NOTE: Test the connector that comes from the engine.
1. Set the meter selector to the AC Voltage position.
2. Test between the three black wires for a total of three tests.
3. With the engine running at the specified RPM, all wire tests must show 60 A.C. volts.
Stator Coil Output
(no load) 60 AC volts @ 5000 RPM
(black to black #1)
(black to black #2)
NOTE: If both stator coil tests failed, check all connections, etc., and test again. If no voltage is present, replace the stator assembly.
Hoppas det kan vara till någon hjälp.
Fix
13 nov 2009
Tack för ett snabbt svar.. Jag ska kolla upp det i helgen, hoppas det löser sig.
